Amp for RE SX
Username: Killer44
Ontario Canada
Post Number: 252
ok so i decided on a RE SX 12", couldnt pass it up, and now i need an amp...willing to spend up to $300cdn, the sub is dual2ohm, so will run @ 1ohm, and is 1000rms...thanks in advance
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1577
$300CND...thats ~$250USD, right?
hummm...
the only amp i can think of (right now) in that price range would be a hifonics titan 1505d or a brutus 1605d.
you may get lucky and find a kx1200.1 or something like that on ebay.
Username: Killer44
Ontario Canada
Post Number: 253
thanx alot man...ya i was thinkin of going w/ hifonics brutus but jsut wanted to check if anyone knew of ne other amps around that price range.
Username: Killer44
Ontario Canada
Post Number: 254
i was just thinkin isnt the kx1200.1 1200rms@1ohm, and the hifonics u jsut mentioned are more then 1000rms@1ohm...and the resx12 is only 1000rms...should i match that rms or go lower>?
Post Number: 1579
An SX should take a bx1605d like a champ.
I have my Sx15 on a jbl bp1200.1 (1300w+ rms), and it could take more.
