What Wattage should i use to run this ALUM12N
Justo914
I was wondering what the wattage should be to run this sub woofer. What should it be running at what amount of Ohms.
Audiobahn ALUM12N
1000W RMS Power Handling
2000W Max Power Handling
PHAT 1.75" EPDM Rubber Surround
Spun Aluminum Cone
Dual 6 Ohm Voice Coils
Multi-connect Lug Lock Terminals
Magnet Weight: 120 Oz.
Frequency Response: 18Hz-500Hz
Efficiency: 96.4dB
Voice Coil: 3" Dual 6 Ohms
Mounting Depth: 5 5/8"
Username: Alexv305
Tavernier, FL USA
Post Number: 69
get an amp that is 2 ohms mono stable with about 1500rms or so, but no less than 1300rms
