Whut amp should i use?
Username: Karim101
Vancouver, Bc Canada
i got 2 12' mb quart subs (rwc 304) dual voice coil...i dont know whut kind of amp i should use that will do the job?? Something not extremely expensive..
Username: Rovin
Trinidad & T...
Post Number: 2528
Nominal Power Handling 225 Watt
Powered Non-Powered
Technical Features
Peak Power Handling 300 Watt
Frequency Response 18 Hz - 300 Hz
Sensitivity 86 dB
Impedance 4 ohm (Dual Coil)
get JL 500/1 if u can afford it ....
