Silver Member Username: NewbPost Number: 193 Registered: Dec-03 | i was wondering if i could get e little input. im currently shopping for a 7.1 receiver to power the speakers i already have. my budget for the receiver is $400 or less. currently i only have one pair of speakers and a sub. theyre jbl e-30's, 70wrms(i know everyone hates them but i did prefer them to other higher end speakers within the same price range). i found 7.1 receivers for onkyo, harmon kardon, and yamaha for 300-400$. all of them put out 75w per channel. i was wondering is there a big difference between these three. or is it pretty much subjective. i listen mostly to bass heavy music and also want to use this system for movies. i plan to buy a center channel and another set of speakers in a couple of months, maybe jbl e-100's. thx for any suggestions |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 6579 Registered: May-04 | Put your question here; https://www.ecoustics.com/electronics/forum/home-audio/18.html, and you'll get more responses. |
