All the New BINs for PANSAT are with Clone Kill
Username: Ikaleem
Black list has posted that all the BIN files he will be posting for PANSAT will come with Clone Killer. Does this mean that the Clones may be useless in future or can the keys be updated with existing recievers...
Username: H3lt3r_sk3lt3r
Post Number: 686
BL is a douche, he has a funny way of looking at things, it's OK to jack DN for their signal, but it's not OK for those companies to clone pansats.
@Imran Kaleem
Here's an advice, simply don't download from future-fta, other reputable dss sites remove the clone killer before they post the new bin.
Username: Thill1951akalk
Post Number: 825
CLONE kILLER MEANS...WILL KILL CLONES OF PANSATS and U will not be able to use those Pansat files x75BL,x85BL,x87BL,x95BL,x05BL..plain and simple!...U will have to use bins/files from other coders not made by BL and that say NON Clone Killer
Post Number: 826
BTW...there is now a clone of the pansat 2700..its the P-2700...so beware!
Post Number: 827
and if U want TRUE original pansat files then download them from [link removed] ...home of Blacklist and genuine pansat files..but beware BL did say ,he will be making Pansat CLONE killers,so U better know what U have is genuine or NOT...and there have been 1000x threads here in the archives , explaining how to tell the difference..
Ana Lee
how do you know if urs a clone or not? i thought if you just perform factory setting it will work normal.
Post Number: 691
@Ana Lee
If you're using it for TRUE FTA then yes, otherwise your receiver will be dead.
blacklist sucks
blacklist sucks little turtle peters the clone killer and pansat killer too . be prepared to buy a new receiver if you use that time bombing crap
he's after all the 2500's so he can sell you guys some more crap. tic tic tic.
Username: Spank
Post Number: 310
C&P from another site:
Blacklist and Pansat have done it again folks. They are killing both clones and legit Pansats with their new files. It is advised that you DO NOT use the new Pansat files at this time.
Al7bar will ban anyone who even brings up a complaint about this!
Panarex, Blacklist and Al7b*r.tk are certainly making enemies by doing this. Hopefully people will boycott Pansat for such poor decisions.
What's the difference between God and Blacklist?
God doesn't think he's Blacklist.
