Anonymous | I was thinking of adding a new sub to the RCA 500 watt 5.1 Receiver ($139.99 -WHOO HOO) . The sub that came with the system seems a little weak. Soooo, Can I add a new more powerful sub that has a power cord and has its own amp??? THanks |
Bronze Member Username: Bigmike27Post Number: 12 Registered: Nov-05 | Yes you can thats why they sell different subs lol. U should have the sub woofer jack on the back. Just pick an amplified sub buy it, plug it in, hook up the rca jacks and ur good to go. How much u looking to spend on a sub. email me with questions at michaeldebincaleb@yahoo.com |
Damian Gator Unregistered guest | Mikael, Thanks for the Help. I went ahead and took the RCA back to Wally World. I read several post on this site about problem with it, which I was also experiencing (during the playing of a DVD, the sound would cut out for 2 seconds once every hour) . It had what I was looking for, digital hookups and cheap, but it was underpowered (my Great room is 19 x 19) and I thought I needed to start over. I think I will be buying reciever, a sub and a center instead of the "Theater in the Box". My front and rear speaker are solid, so I want to take advantage of them. Thanks again- Damian |
