Unregistered guest | i have a 97 dodge dakota and the only way i can get power is if i hook up my acc and my battery wire to the power on the truck... but whne i do that i have no memory i cant figure out wat wire i should hook up my acc to...and when my battery is just hooked up to the power all my deck says is (SEE YOU) and then shuts off and wont turn back on ???? |
Gold Member Username: IlluminatorUSA Post Number: 2267 Registered: Apr-05 | The acc and battery are not meant to be wired together. The Acc goes to what you call the 'power' and the battery goes to what you call the battery. http://www.bcae1.com/installationprimer.htm I highly suggest you read that. |
