Alpine amps
Username: Ford_on_20s
Jacksonville, Florida Us
Post Number: 46
im going to get 2 10'' type r's and stick them in a q logic sealed box. im wondering if i need to get the dual 4 ohm or dual 2 ohm subs to run with the alpine mrd 1005 amp
Post Number: 47
anybody ? lol or is there another amp better for 2 type r's?
Username: Bga44
Tampa
Post Number: 139
wuts their rms
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1364
4 ohm so u can wire them down to a 1 ohm load or 4 ohm load, i u got the 2 ohm u could wire them to a 2 ohm or 8 ohm load
Username: Bga44
Tampa
Post Number: 140
wut is their RMS, the new ones are 500RMS. the old i think are 350RMS. u need to find a 1000watt RMS amp.look for kicker amps that give 1000RMS in 1 or 2 ohms
Post Number: 49
yea the rms is 500...and here is the specs for tha amp...500W x 1 RMS (4ohm, 12.0V, 1% THD+N)
700W x 1 RMS (2ohm, 12.0V, 1% THD+N)
700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
Username: Bga44
Tampa
Post Number: 141
get the dual 2ohm subs. and wire it to a 2ohm load. wut amp is it?
Username: Bga44
Tampa
Post Number: 142
wut brand amp? u know how to wire it to a 2ohm right?
Post Number: 50
the mrd 1005
Post Number: 1372
get the 2 ohm subs since your amp is not 1 ohm stable
Username: Tjmutlow
Post Number: 156
Get the 2ohm , and wire them to a 4ohm load, then run series, it will produce 2ohm load
Username: Bga44
Tampa
Post Number: 143
go to this site, u put how many subs u have and their impedance and it shows u different ways to wire it and what the ohm will be
http://www.cardomain.com/item/KIC04S10L742
go there and then wiring options under specs
Post Number: 1375
http://www.the12volt.com/caraudio/woofer_configurations.asp
