Silver Member Username: ShawnomakHB, SK Canada Post Number: 133 Registered: May-05 | what do you all think of MA Audio? i was looking at the MA Audio M1889I amp, but i dunno what they're like. theres a site with them for $130.00 and thats pretty cheap i think, should i get it? what can you tell me about the brand or that amp. its a 800.1 i think. thanks for any help |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1189 Registered: Jul-05 | Dont do it http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 134 Registered: May-05 | What is wrong with that brand? not reliable or just not worth getting? |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 306 Registered: Oct-05 | if alot of people say it's not good, then don't get it. i never used ma audio stuff but it seems like alot of people think it's not good. you are probably gonna want something better after you buy that so you are gonna be spending more money. |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 135 Registered: May-05 | alright, thanks.. any ideas for cheap 800.1 or 600.1 mono amps? i can probablly spend a bit more than what that amp is, lol, but i dont want to if i dont have to. |
Gold Member Username: RovinTrinidad & T... Post Number: 2273 Registered: Jul-05 | if its 600wrms @ 2ohms u are asking about ,then JBL 600.1 Alpine 600.1 phoenix Gold xenon 600 MTX Rockford fosgate Kicker 04SX650.1 don't be cheap now & regret it later ......... |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 599 Registered: Oct-04 | ma audio = audiobahn Same company. |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 316 Registered: Oct-05 | i heard many good things about kicker amps. well i use one myself and they are nice. |
Silver Member Username: 54danny54Post Number: 946 Registered: Nov-04 | Great brand in my opinion. i swear they get loud man |
Silver Member Username: 54danny54Post Number: 947 Registered: Nov-04 | im talkin bout MA |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1206 Registered: Jul-05 | so does audiobum, a lot of stuff can get loud, but only a few can get loud and sound good while doing it |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1392 Registered: Jul-04 | i run an MA audio amp, doesnt over heat at all, puts out desent power, not exactly a sound quality amp but if you're looking for power at a desent price they arent all that bad. |
Silver Member Username: 54danny54Post Number: 948 Registered: Nov-04 | all im sayin is i personnaly love MA |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 136 Registered: May-05 | ok, im confused.. right now i have 2 infinity 1230's and an infinity 310a amp, but that only puts about 150w rms to each 300w rms sub, so i want a little bit more powerful amp. That ma audio amp is cheap and i can always get somthing better later. so... should i get it or save more and look into a better brand, i hate when answers are 50/50, lol thanks again |
Bronze Member Username: CrazydudePost Number: 11 Registered: Nov-05 | you are gonna get sick of the p.o.s. real fast. save more and look into a better brand. |
Silver Member Username: Robert_dMIA, FL USA Post Number: 362 Registered: Sep-05 | shawn your 1230's are dvc 4 ohm right ? if so you amp is a mono amp (2 ohm stable) wire 1 subs to 2 ohms and run it off one amp and just buy another 310a and run it to the second sub (an amp to each sub) |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 139 Registered: May-05 | they are svc 4 ohm subs |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 140 Registered: May-05 | so if i have them wired in parallel,(2 ohm load) each sub would get 150 of the 300 W, am i right? because that amp puts out i think 312Wrms at 2 ohms. |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 141 Registered: May-05 | so if i have them wired in parallel,(2 ohm load) each sub would get 150 of the 300 W, am i right? because that amp puts out i think 312Wrms at 2 ohms. |
Silver Member Username: ShawnomakHB, SK Canada Post Number: 142 Registered: May-05 | srry for the double post, my computer messed up |
Bronze Member Username: CrazydudePost Number: 22 Registered: Nov-05 | shawn why don't you get kx1200.1 amp. this amp is 600wrms at 2ohm. also it is 1200wrms at 1ohm so if you ever decide to upgrade your subs you can. you can find kx1200.1 on ebay for around $300 |
Silver Member Username: PhuktupbassheadScottsdale, Arizona United State... Post Number: 328 Registered: May-05 | are phoenix gold amps any good? (sorry, i saw someone mentioned them a couple posts ago) |
