True watts on ajl 1000/1
incognito
i had i ppi 1600 watt just burned up ....then put in jl 1000/1 and it like twice as louud..but it only 1000 watts?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1409
is the ppi rated 1600 watts at 14.4 volts or 12
incognito
not shure it a pcx 24000...it burned up last night...and i had the jl sitting around had a 13.5 w7 i dont like it...but i do tink its a 14.4
Username: Rovin
Trinidad & T...
Post Number: 2460
is that 1600 MAx watts or was it the way your sub(s) was wired ?
well now that proves what 1000wrms or so of pure clean undistorted power can do ......
incognito
true .....had it for a wile bought it used and ran it with my 15's then last night heard a pop then it was gone was a good amp ....it did have a 0.02thd and it did crank but i guss i pushed it i little to hard but the jl save my asssss:-)
Username: Lanzarchamp
Bakersfield, California United States
Post Number: 242
you dont like ur 13.5 w7, everyone i know that has one has never had any complaints about it>
is the sq not good, or was it the spl output you didn't like
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 183
it doesnt seem like anyone clarified this yet, but the jl has a regulated power supply, meaning it puts out a true 1000 w all the time, even from 11-14.5 V, and at 1.5-4 ohm. I hope to get one, one day.
Username: Tdbdadrummer
Post Number: 679
"and i had the jl sitting around had a 13.5 w7 i dont like it" - Dude, if you don't want that, what do you want for it? I'd give you about $300! I mean, you don't want/like it, and it's used...Plus the chance I wouldn't like it...
Post Number: 680
Or ya know, you could just send it to me for free. I'd appreciate it.
Post Number: 681
I could hook that beast up to my Audiobahn A8000T. It's 750W RMS right? I can run 800W RMS to it! w00t! You know you want to give me that W7!
Los Angeles, CA USA
Post Number: 452
13w7 is 1000wrms but can handle more cause its underrated. it is also dvc 3ohm. there is no way of hooking that sub up to a8000t.
Post Number: 690
Well, Chad, that statement isn't totally true. There's a way to hook up any speaker to ANY amplifier, be it a 1000W RMS JL Audio 13w7 to a 10W RMS Kenwood 1980's KR-2600. Whether it will be POWERED correctly is another story.
As far as the ohms go, as long as it didn't go below 2 ohms, the A8000T can be run at 3 ohms, they just don't offer a power output for it at that impedance.
I could be wrong, but Chad, your statement is rather misinformed.
Post Number: 691
Actually, I just checked and since I would be running ONE 13w7, it is very much possible. The drivers are 1.5ohm DVC, not 3 ohm. At least that's what JL's site says, but there's always the possibility they could have no idea what their subs are rated at...
Anyways, so wiring one 1.5ohm DVC sub in series gives you 3 ohms. I would be running a bit under 800W RMS, probably like 650-725ish, but it could still be done.
Username: Rovin
Trinidad & T...
Post Number: 2499
to put an Audiobutt amp on a 13w7 is just a disgrace - sorta like a stray dog jumping a prized pedigree doberman ........
