8 gauge power and ground from distribution block
i have 2 rockford 501bd's and a 1 farad cap w/ a built in distribution block (and a high output alternator). it says the amp needs 4 gauge power and ground. can i run 4 gauge power and ground to the caps distribution block then run 8 gauge power and ground to each amp? since the distribution block goes from 2 4 gauge to 4 8 gauge.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2193
the amps are 500wRMS @ 2 ohms each
you could use 8AWG for each amp and ground from the dist block yes, but keep the runs from dist block to ground point a total of less than 6 feet each.
"but keep the runs from dist block to ground point a total of less than 6 feet each."...im sorry i didnt understand that part, could you explain that again, thanks.
Username: Glasswolf
Post Number: 2197
USE LESS THAN SIX FEET OF EIGHT GAUGE CABLE FOR EACH AMP
TOTAL
THAT'S FOR GROUND AND POWER.
I typed it really slowly, too.
I hope that helped.
Username: Glasswolf
Post Number: 2198
use a maximum of 6 feet of 8ga. wire for each amp, including both positive and ground.
going over 6 feet with 8AWG exceeds the peak rating for 8ga cable at that amount of current.
~500 watts
thanks i really appreciate the help, but you dont have to make the smart comments. people on this message board actually do have lives other than knowing everything about car audio.
Username: Glasswolf
Post Number: 2202
yeah and some of us try to have lives when we're not re-explaining teh same crap to people 12 times to get through to them.
this stuff is all easily found on the web with a little effort and looking.
people are just too lazy and what it all done FOR them.
I don't know why I waste the time some days.
