Clueless
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 84
I just got broken into and I'm pissed off. I want a 2 way alarm with sensors in the door handles so they dont even think about it. I want it loud very loud... any sugestions i have no clue wat to get how much to spend
Username: Tjmutlow
Post Number: 140
Do not buy an off brand one, try DEI product and use dual stage prox sensor for. Try the hornet 564t, nice alarm
Username: Catalin
Surrey, BC Canada
Post Number: 37
Don't bother with DEI and any of their products. Lots goes into marketing and not enough in r&d... If you want two Compustar/Nustart has everyone beat hands down.
Make sure you have it installed with horn honk in addition to the siren it comes with and it will be quite loud. Adding a back-up siren will get you some more security and sound... but if you want it real loud you can also have some air horns installed to honk with the alarm when it triggers.
