Speaker Covers
Username: Klammer
Post Number: 12
I just bought a house with several in-wall rectangular Speakers. One of the covers is missing on one of them. Where can I buy replacement covers for the missing one? I know I will probably need to do a pair to make them match.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 365
I have it on e-bay.
Username: Nuck
Post Number: 366
Sorry Ken, I just couldn't resist!
Take the one you have and made a twin or a pair.
Cover with colour of your choice.
Cheers
Username: Klammer
Post Number: 13
My question still stands. The wall cover is missing on one and I need to replace it.
Rantz
Ken, how can anyone help when you don't tell what brand the speakers are. I would try to locate the brand and model number - then google the manufacturer to get the contact details. Other than that take Nuck's advice and make one!
Username: Jan_b_vigne
Dallas, TX
Post Number: 6600
DOH!!!
Username: Klammer
Post Number: 15
OK I looked on the back of one and discovered it they are ELAN ES925 speakers.
I sent an e-mail to ELAN looking for where to get a replacement cover and have not heard anything. Is there another avenue I should be looking at?
Username: Nuck
Post Number: 464
wide eyed smiley here
Username: Fps_dean
Williamstown, MA USA
Post Number: 155
Ken... I would go about it the same way as you did.
