Just got one but the coax connection aren't labeled well, just says circular and linear. Can some one tell me which are the vert/horizontal and left/right hand connections. It's not even on invacom's website!
Hi, Anon, sorry I can`t answer your ?, but if you don`t mind I`d like to ask you 1, a friend wants to upgrade his c-band to pick up ku, how much was the invacom and where did you get it? The ones I found seemed very expensive, but I don`t know. Thank you.
Thanks Hitch, I have that much. The LNB connections are labeled "C L C L" (from left to right. I want to know which 'C" is Left and which is Right, and which "L" is Horizontal and which is Vertical. Sorry I wasn't more clear the first time.
The ports do both. There isn't one right circular port and one left circular port. The selection happens internally based on the voltage sent to the LNB by the reciever. The 'quad' nature of this LNB allows you to hook up multiple receivers.
