Unique Set Up Needs Help !
Username: Darkulti
Hi everyone, I'm a newbie here with few knowledge of audio system. I have spent days reading information on magazines and internet, but I am still confused. Your expertise in setting up a unique audio system will be very helpful to me.
I would like have an audio system to produce a sound inside and outside my small condominium, 40' W x 80' L = 3,200 Sqft. no rooms inside with 5 floors.
Inside Criteria:
1. Run 24hrs - two cds producing two different natural sounds with frequency range of 1.5 KHz - 5.5 KHz output.
2. The sound inside the building should be able to reach a peak level of 100 - 120 db as rock band concerts.
3. The average room temperature is around 86 Farenhiet.
My questions are:
1. Which required equipments will suit me best, Receivers, Power Amplifiers, or Integrated Amplifiers?
2. Should I purchase optional equipments?
3. Any other recommends ?
All advice is appreciated. Thanks for all your kindness.
Username: Stu_pitt
NYC, NY
Post Number: 770
Gte one of these for each area you need clean and loud music -
http://www.harveyonline.com/products/details.asp?sku=265&auth=KMOJG&r=0&category %5Fid=4&subcategory%5Fid=49702&page=2&order%5Fby=a%2Emfgr%2C+a%2Emodel%2C+a%2Eti tle&mscssid=WT8JW3BX8KTR9KELC1CA4TFP88156421
