Bronze Member Username: FillymoPost Number: 16 Registered: Dec-03 | If anyone is selling or know where one is to buy for a jbl bp1200.1 Amplifier Please email or post with quotes. Ive seen them sell for 150 used and 260 new something between there would be good. |
Bronze Member Username: FillymoPost Number: 17 Registered: Dec-03 | My email is wazdat07@aol.com : ) |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 1771 Registered: Dec-03 | eBay has good prices on them or www.etronics.com has them for a fair price new. |
Anonymous | i was thinking about getting on eof these 2 are they any good?? |
Bronze Member Username: FillymoPost Number: 18 Registered: Dec-03 | Yea they are good Just my altenator couldn't supply full power for it : ( Im not talking headlights dimming im talking headlights off |
Silver Member Username: Its_bacon12Post Number: 369 Registered: Dec-03 | lol yes JBL makes very reliable amps and the bp1200.1 would draw ~114A continious |
Bronze Member Username: FillymoPost Number: 19 Registered: Dec-03 | I also hear The trantrun ti1200.1 are really good too tell me what would be best for a solo baric l7 15 With wiring for 2 ohms I had the JBL amp before if i get a Tantrum amp will it be better ?all information u have about both amps would be much appreciated thx |
gg Unregistered guest | gg |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 2066 Registered: Dec-03 | if both amps put out 1200 watts @ 2 ohms, I doubt you'll notice much difference. |
McShmiggidy Unregistered guest | Should be a difference in amps I mean. For one Jbl is missing a subsonic filter, Also you would need to know how long both are said to last and what the rms is for a PGTANTRUM at 2 ohms I know they give the 4 ohm rms. I have heard the tantrum has some special circuit design to make it more effecient. I hope this helps you more then " I doubt you'll notice much difference." I think glasswolf is burned out on answering questions |
