Username: Pat99 Post Number: 1 Registered: Nov-05
Sunday, November 06, 2005 - 21:56 GMT is this a good amp for my 15" Rockford T1
Alabama
U.S.
Post Number: 1057 Registered: Jul-05
Sunday, November 06, 2005 - 23:13 GMT why not get the A8000T, since its a mono amp, but the A8002T should do fine, but if u havent bought it yet whats ur budget
Username: Cadillacdb Houston ,
TX
Post Number: 36 Registered: Aug-05
Sunday, November 06, 2005 - 23:52 GMT Probably only plannin to spend 150 since thats how much you can get that amp for on ebay
Username: Pat99 Post Number: 3 Registered: Nov-05
Monday, November 07, 2005 - 04:28 GMT ya my budget is around 150 160 somewhere around there is there a better amp for the money?
Alabama
U.S.
Post Number: 1082 Registered: Jul-05
Monday, November 07, 2005 - 04:30 GMT nope, even though Audiobahn isnt the best, if your on a budget Audiobahn and Hifonic are the way to go
Username: Pat99 Post Number: 5 Registered: Nov-05
Tuesday, November 08, 2005 - 06:50 GMT alright thank u i got the Audiobahn A8002T and the bass remote for 153 shipped is that a good deal?
Alabama
U.S.
Post Number: 1143 Registered: Jul-05
Tuesday, November 08, 2005 - 06:54 GMT thats pretty good, is it new or used
Alabama
U.S.
Post Number: 1144 Registered: Jul-05
Tuesday, November 08, 2005 - 06:56 GMT just make sure u bridge it
Username: Pat99 Post Number: 7 Registered: Nov-05
Tuesday, November 08, 2005 - 23:57 GMT it is new
Username: Safa19 Post Number: 90 Registered: Apr-05
Wednesday, November 09, 2005 - 04:53 GMT i have the a8002t and i bridged it to one sub and it over heats in like 5 songs so i had to put it back to only 400 watts audiobahn really does suck spend the extra money and get something better it will be worth it in the long run cause now im looking to get an orion amp and its costing me an extra 150 cause that amp died in less than a year
Alabama
U.S.
Post Number: 1180 Registered: Jul-05
Wednesday, November 09, 2005 - 05:30 GMT where did u have ur amp mounted
TX
Post Number: 63 Registered: Aug-05
Thursday, November 10, 2005 - 02:49 GMT Joe if it always over heated in less then five songs i believe that it was most likely a mistake on ur part that lead to its short lived life
Username: Safa19 Post Number: 93 Registered: Apr-05
Sunday, November 13, 2005 - 20:33 GMT it was mounted on the back of my rear seat and circuit city installed it and did all the settings i never touched it so idk what would be wrong with it
Username: Crazydude Post Number: 62 Registered: Nov-05
Sunday, November 13, 2005 - 20:56 GMT it was either poor installation or the amp itself had a problem to begin with. i don't think audiobahn makes their amp to overheat like that.
