Help with Jensen Head Unit
Username: Judge
I have been experiencing a little problem with a Jensen MP5010K head unit. It is hooked up to the the car speakers in a standard fashion and to a subwoofer through an amplifier. Since a week ago, the head unit has started to give some trouble. For some unknown reason, it would go from playing good to playing only through the sub for a while. Eventually (after a few hours) it would just go back to normal and sound would come through all the speakers. It would stay normal for a while and then go back to just sound through the sub.
What could be the cause of a problem like this? Is this a result of a short somewhere? Does this mean that the head unit is starting to go downhill? I have had it for about 16 months now and it has always been working fine until this problem.
Please help. It's frustrating to drive without good sounds.
Username: Illuminator
Post Number: 2163
It might be going bad, especially due to the somewhat bad build quality (It's a Jensen). But I would check all speaker connections before going any further.
