do these subs require large cuft for it to sound good. i am thinking about a setup with either 2 12 resx or one 15 resx. if 1.7 cuft is good for these subs then i can go with 2 12s but if not i would have to go with 1 15. also to power these subs i am thinking rockfor fosgate power T20001bd. it's 2000wrms @ 1 ohm.
Well... if you wanted to do 2 12s you would have to get them custom dual 4 ohm to result in a 1ohm load. I think you'll be happy though with 1 15" getting about 1000w.
i didn't think about that baseball. so re can do that for you? i mean make it dual 4ohm. what do you think about the fosgate amp for that baseball? if you have suggestions on other amps i would appreciate it.
matt i have a 1200wrms amp putting power to two type Rs and they are loud as hell. and i just changed the box from slot port to sealed and the sealed sounds alot cleaner. its also pretty loud too.
