Bronze Member Username: Scott_tPost Number: 58 Registered: Sep-05 | what guage amp wiring kit do i need to wire the orion 1200D amp? |
scotty too hottie Unregistered guest | probably 2 gauge you can even go with 4 if you dont have the money. |
Silver Member Username: QuickshotCharlotte, North Carolina U.S. Post Number: 359 Registered: Aug-05 | nah go 0/1 gauge for sure my mtx thunder 942 wont work unless it has 0/1 gauge and your amp is pushing about 300 more watts than mine |
Bronze Member Username: Scott_tPost Number: 59 Registered: Sep-05 | 2 gauge is 1500 watts i think the orion is 2400 peak. and am i going to need a new alt? |
Bronze Member Username: Scott_tPost Number: 60 Registered: Sep-05 | where can i get 0/1 gauge wire at? can you give me a few places to look. and can my stock alt on a monte carlo ls handel the amp? |
Gold Member Username: RovinTrinidad & T... Post Number: 2078 Registered: Jul-05 | use this guide http://www.the12volt.com/info/recwirsz.asp any good audio store should sell it . If your headlights blink - then electrical upgrade is needed . U can also have the voltage tested to be sure when the system is playing full blast ..... |
Silver Member Username: James_gTN Post Number: 367 Registered: Jul-05 | Knu Konceptz....for wire. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1039 Registered: Jul-05 | All wire is the same, just get good RCA cables |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1395 Registered: May-05 | so long as they have a good connection, all rca's perform the same. |
Bronze Member Username: TjmutlowPost Number: 94 Registered: Sep-05 | First of all look at what the amp requires, if that is the only amp you are running except maybe a 4 channel it can be run on 4guage. Do use good rca's. |
Bronze Member Username: CrashfactoryxPost Number: 19 Registered: Oct-05 | I have a question on this too, I have 0 gauge from my battery to my distribution block (i used to have a 1600 watt amp that I thought would need it), I now only run little amps (POS's at that, cuz I'm poor :P), is it detrimental to have that big of wire to little amps? I fried the 200watt POS VR3 I had, so far the 250watt Sony Xplod is doing alright..anyone? |
Gold Member Username: RovinTrinidad & T... Post Number: 2160 Registered: Jul-05 | If u already have that fat wire - leave it as long as it can fit into the amp , it should not be any harm ... |
