Ported Box for 12" X.X.X
Username: Solacedagony
New Jersey US
Post Number: 583
Just wanted to check on what size and port tuning you guys have your X.X.Xs at. I went to RE's site to check out their suggested specs and I came up with 2.1 cuft @ 28hz (for SQL). Any comments on that?
Username: Subman15
Lwarenceburg, Kentucky United states
Post Number: 30
you should just go ahead and make the box from the specs. it should work the best.
New Jersey US
Post Number: 587
Yea I figured, I just wanted to see if anyone else had experimented with it and what results they had gotten. Thanks.
