Newbie need links/guide info
Username: Scubaroy
I am moving and think I want to go with a projector,seems you can get one for same price as plasma tv and picture would be bigger, but not sure if it would work if i have some ambient lighting in front room.
Dont know anything,pros/cons,native ratio etc.
Any links to get me started
recomendation on projector/screen for under$2500
What is better between svidio,dvi hdmi and composite??
Thanks,roy
JohnQ
Take a look here they have complete packages that fit your budget. You can even customize a package if you want.
www.digitalhsolutions.com/Home-Theater-Packages/Home-Theater-Packages.html
