Will this work
salxman12
hi. i dont really know much about how what it means when something is like dual 2 ohm insed of none dual but would hooking up a dual 2 ohm sub like this one
http://www.sonicelectronix.com/item_1817.html
to a 1 channel amp like this one
http://www.sonicelectronix.com/item_2681.html
work? im just all confused now bucause on the pic of the sub theres 2 sets of inputs like 2 +'s and -'s does this have to be like one from a difernt channel of an amp or the same one? im just so confused someone help me. and if it does work is that a good combination?
Username: Thumper
Richmond, VA U.S.A
Post Number: 156
Well... not if your looking for good sound quality. That subwoofer is used for very small enclosures so thats really the only benefit. I would go for something in the alpine line of subwoofers. Try two 12" type s or type R. Then get a mono amp to power them. Now, how you wire your subs will depend completely on how you want to run them.
This Link will show you aeveryway to wire your subwoofers to you amp
http://mobile.jlaudio.com/support_pages.php?page_id=145
and this one for other questions
http://mobile.jlaudio.com/support_pages.php?page_id=141
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 161
many people here will probably wanna talk you out of those 2 brands so i wont even get into it. But if thats what you want, yes it will work. You will end up wiring the two 2 ohm voice coils in parallel to get a single 1 ohm load, which you will connect to the amp brigded. You will only connect one pos and one neg to the amp. Since your new to all this, try reading www.bcae1.com a few times if you wanna learn something.
