Refurbished?
Username: Mattman111
Keizer, OR US
Post Number: 47
what is factory refurbished and is it bad to buy it or is it ok?
Username: Rideredder
Cornell, IL USA
Post Number: 86
Factory refurbished means that the unit had gone bad and had been sent back to the factory to be fixed. You should be alright purchasing refurbished itmes. Plus, the price will be marked down a bit, but it should be good as new.
Username: James_g
TN
Post Number: 362
Be careful and do your research. Alot of times refurbs are only slightly cheaper than brand new models. If that's the case, there's no reason to buy the refurb.
I've seen some refurbs go for $330 when you can get a new model for $360. That makes no sense.
Keizer, OR US
Post Number: 48
theres a refurbished orion 250 g4 on ebay for 290 and i was looking at that for my avalanch but im not sure
Keizer, OR US
Post Number: 50
To the TOP!!
Username: Tjmutlow
Post Number: 93
Try to get ones that are factory refurbs, orion does not refurb or fix any of their product and have done so in years.
