ported. probably around 3 cuft each. search google for tuning theres alot of different sites that show you how to do it.
frkkevin
Win ISD (pro) will give you the port length for your box. Just need to enter in some speaker info and box size then enter in how big you want the port and it will give you the length to tune it to X hz.
