I've been wanting to buy these for a long time, but I just wanna know; am I getting my money's worth and can the jack fit into small outlets? I wanna connect this to my CD Walkman. Please send feedaback. Thanks.
Yes they can. It has a twist on adaptor for bigger outlets of which you just screw off so it may be powered by your Walkman.
They're cheap, probably have a decent sound however. It's up to you. Have you looked at Sennheiser?
red.rocket
I've looked at Sennheiser. I just don't have enough money for them. I live in Canada, the cheapest set of Sennheisers were $69.99. But since I've heard such good reviews about these Sony ones and I have enough moeny for them, I'm gonna make a purchase on them.
If you can find the MDRV700, those are pretty nice...
red.rocket
MDRV250V. Are these headphones any good? I'm also considering buying these because they are the same price and have a few more features than the XD200. Please reply. Thanks.
The MDRV250V's are actually really good headphones. I had the nicer silver version and they had a good sound. I would take the MDRV250V's over the XD200's.
