Sony KDFEA20 vs. XS955?
Username: Drtrouble
Which one is the better of the two? I think the XS955 is the older of the two but as I look, it's still more expensive.
What's the difference and which would you recommend? Any major problems with either one?
Username: Ironvalor
Post Number: 14
im not sure about the XS955, but i have the sony
KDFE55A20 55" LCD and its perfect for the the
applications i run with it.. i just bought
star wars III , looks awsome in wide screen.
i hooked my PC to it .. great monitor for
Games and internet ... no lag, blur just
awsome gameplay. next will be XBOX 360.
you have to have an updated graphics card
that can push high-res for your PC, but this TV rocks,
im sooo glad i did'nt settle for anything
under 50 inchs. monday night football
looks so good you can't stop watching!
thats my input.
later.
Username: Imustbecrazy
Post Number: 44
www.sonystyle.com
A20
Specifications • Audio
• Sound Mode: SteadySound
• Sound Mode: Dolby Digital
• Sound Mode: TruSurround XT
• Speaker Output: Treble, Midrange, Bass, and Balance
• Sound Mode: BBE
• Sound Mode: Simulated
• Sound Mode: Auto SAP/MTS
• Speaker On/Off: Speaker Off
• Speaker Output: Audio Output (Variable/Fixed)
• Sound Mode: Volume Offset
• Sound Mode: A/V Sync
• Audio Format: Dynamic, Standard, and Custom
• Video
• Panel Type: LCD 0.87" (1366 x 768)
• Aspect Ratio: 16:9
• Tuner: Terrestrial (VHF/UHF/CATV)
• Tuner: ATSC
• Tuner: 8VSB
• Tuner: Clear QAM
• Tuner: POD QAM
• Video Signal System: NTSC
• Type: WEGA Engine
• Type: DRC-MF V1
• Type: CCPX
• Video Signal System: 480i
• Video Signal System: 480p
• Video Signal System: 1080i
• Video Signal System: 720p
• Picture Modes: Vivid, Standard and Custom
• Picture Adjustment: Picture, Brightness, Color, Hue, Sharpness, Color Temp, NR, DRC Mode, DRC Palette, Clear White, Black Corrector, Gamma, and Color Corrector
• Advanced On-Screen Menu: Freeze, Favorite Channel, Channel Label, Channel Skip/Add, Video Label, JUMP, Channel Surf, Parental Lock, Closed Caption, ID-1, and Initial Setup
• Type: MID
• Type: DCP (Display Component Processor)
• Power
• Output Power: 12w x 12w
• Power Requirements: 120V 60Hz
• Power Consumption: In Use: 210 Watts Standby: Less than 17 Watts
• Inputs and Outputs
• Input(s): RF 75-ohm F-type
• Input(s): Cable 75-ohm F-type
• Input(s): POD PCMCIA-type
• Composite Video Input(s): 3 (F:1/R:2)
• S-Video Input(s): 3 (F:1 R:2)
• Component Video (Y/Pb/Pr ) Input(s): 2 (F:0 R:2)
• Input(s): Total Audio Input (LR, RCA-pin) excluding HDMI 5 (F:1/R:4)
• Digital Audio Output(s): (Optical) 1 (F:0/R:1)
• Headphone Output(s): 1 (F:1/R:0)
• Input(s): Incorporates HDMI technology. HDMI + Audio L&R
• Convenience
• On Screen Controls: English/Spanish/French
• Timer Clock: Clock, Sleep and On/Off Timer
• LED: Power/Standby1, Timer, and Lamp
• ID1 Detection
• Auto SAP
• Video Label
• Closed Caption (CC)
• Freeze Memo Screen Freeze
• Favorite Channel
• Channel Label
• Channel Skip/Add
• Channel Jump
• Parental Control (V-Chip)
• Optics
• Zoom: Wide Zoom, Normal (480 only), Full, Zoom, Game Picture Adjust, H/V Center Adjust, Display Area, Vertical Center Adjust, and Vertical Size Adjust
• Weight
• 92.5 lbs (42kg)
xs955
Specifications • General
• Power Requirements: AC 120V 60Hz
• Component Video (Y/Pb/Pr) Inputs: 2 Rear (1080i, 720p, 480p, 480i)
• Composite Inputs: 1 Front/ 3 Rear
• S Video Inputs: 1 Front/ 3 Rear
• Audio Input: 1 Front/ 6 Rear
• Control S (IN/OUT): 1 Rear
• Subwoofer Out: 1 Rear
• HDMI with Analog Audio In: 2
• CableCARD Slot: 1 Rear
• Audio
• TruSurround SRS Audio Processing
• 30 Watt, 5-Speaker System: 5 Watts Left and Right Channel; 20 Watts Subwoofer
• Dolby Virtual Surround Sound
• BBE Sound Enhancement
• TruSurround
• Simulated Surround
• Steady Sound Automatic Volume Control
• Video
• ATSC Integrated Tuner
• CableCARD Slot
• 1,092,168 Million Dots per Panel
• Sony's Proprietary WEGA Engine System
• Flexible Twin-View 2-Tuner Picture-and-Picture (HD, NTSC)
• CineMotion Reverse 3-2 Pull-Down Technology
• BN Smoother
• Wide XGA LCD Panels
• Wide Modes (Normal, Full, Zoom, Wide Zoom)
• 0.87" WXGA LCD Panels
• Memory Stick Media Enhanced Playback
• Optical Engine
• Clear White Circuit
• Black Corrector
• Gamma Corrector
• Detail Enhancer
• High Resolution Panel
• Video Label
• Sleep Timer
• On Screen Display in English/Spanish/French
• Program Palette Presets
• Speed Surf Channel Selection
• Auto Channel Program
• Caption Vision (CC)
• Channel Fix
• Channel Label
• Channel Skip/Add
• Clock/Timer (2 Event)
• Favorite Channel with Preview
• 16:9 Aspect Ratio
• UHP Lamp (132W)
• First Surface Mirror
• 3D Digital Comb Filter
• Program Palette Presets Innovative Low Profile Design
• Energy Star Compliant
• High Definition Television Monitor
• Increased Longevity
• V Chip Parental Control
• Enhanced Memory Stick Media Playback
• Weight
• 105 lbs. 11 oz. (48 kg)
• Dimensions (WxHxD)
• 62" x 37 1/2" x 19" (1574 x 952 x 484 mm)
Here's the big differences:
