E-dead in box
Username: Montecarlos11
Louisville, KY USA
MY question for you all you all is that if i made a box and put in e-dead inside of the box, would it makes the subs sound better or worse in general. If you know how doing this would effect a ported boxand a seal box, that info would cool too :-) .
Username: Solacedagony
New Jersey US
Post Number: 558
I remember somewhere this came up and the answer was that it'd make you hit lower numbers. I don't remember what the reasoning was behind it, however.
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 395
how about that dynaspray the black spray deadin stuff would it do the same j/w
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1456
dont event bother w/ sound deadening in your box...all that is good for is slowing air-flow. (usually a bad thing)
if your box is flexing, brace it...or beter yet double wall it and brace it.
Louisville, KY USA
ok, its just i was curious about what it would do. I was gonna start trying to expeirment with new things to try out. I appreciate your info and saving me money. :-)
