2 amps to 1 sub
Username: Robert_d
MIA, FL USA
Post Number: 283
im going to get either a kicker 600.1 or a xenon 600.1 (doenst really matter for this question)
but if one has ex: 630 rms and the other has like 700 rms would the sub sound wierd since the voice coils are getting different ammount of power
and if your wondering cause i know someone will say "like muddy says, save now and get what you want later" lol
its because im going to go with a single type R until i get my next car in a couple of months and get a sx
also ive read that the xenon has better sq but the kicker puts out a little more power is that true?
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 121
so, are you saying you want to buy one of those two choices right now, and then buy a second once you get the sx? and if this is true, then the kicker would be a good choice since you can strap two kx600.1 together and get 1200w+ , im not sure if you can do the same with the xenon.
Username: Rovin
Trinidad & T...
Post Number: 1974
kicker is higher ranking than PG - so i'd take the kicker ..................
