Sat help
sg21102
I am just curious if I can catch any of the eastern satellites. I live in eastern Ontario in Canada. Want hot bird but I don't know if I could get it. Thanks.
I just bought cool set pro receiver but I don't know how to down load files and how to set up the receiver. i am new to this. I want to learn to set up the receiver so I can receive north ameriacn and asian channels.
Your help will deeply appriciated
Thanks
Username: H3lt3r_sk3lt3r
Post Number: 213
@sg21102
lyngsat .com
@Majamo
Read here (you might also want to consider a 'Search'):
https://www.ecoustics.com/electronics/forum/home-video/35.html
and here:
https://www.ecoustics.com/electronics/forum/home-video/168756.html
sg21102
I want to know which sat's that are in the east that I can catch. I heared you can go too far because of the horizon.
Username: Thill1951akalk
Post Number: 418
go to lyngsat.c*om...lists all the E and W birds..and whats channels on them, and bunch more info..
sg21102
I know about lyngsat. I want to know if i can catch every sat in the east or just up to 20deg because of my location.
Post Number: 419
I believe this hobby is called TESTING, for a reason!
jj22113
Hi I have a fortec lifetime ultra with a eliptical dish 110/119. I get 98 signal quality but am missing some channels on 119. In fact some I am not getting signal strength on some tp's that i should be getting. I know this because i've compared my tps with a friend. I tried flashing with factory bin, powerscan, tp scan and changing position on the switch. Only getting 2 hb channels on 119. Any suggestions?
