I am replacing my old Sony package-HT with something little better within a limited budget. So far, I got Athena Point 5 (front, center and surrounds) and HK AVR235 will be arriving next week. Could somebody pl. suggest a suitable sub to with it in the $150-$200 range ?
Avr235 being 7.1, I am planning to move the front speakers from Point 5 to the rear surround. What will be a good choice for the front speakers then? One of the Athena AS --B series speakers?
Also, do you think the 235 can drive an Athena AS-F1 (200 watts) floor standing speakers ?
Thanks kera
"Could somebody pl. suggest a suitable sub to with it in the $150-$200 range ? "
Dayton 12" (parts express), Cambridge Soundworks Basscube 10 or 12 (ebay, direct from mfr), Velodyne CHT 8, among others. Be advised that a significantly higher quality subwoofer can be had for 299 from hsuresearch.com though.
"What will be a good choice for the front speakers then? One of the Athena AS --B series speakers? "
Yes.
"Also, do you think the 235 can drive an Athena AS-F1 (200 watts) floor standing speakers ? "
