Direct TV H10 reciver (hdmi)
Username: Angel_l
Miami, FL. USA
Deos it make a differance to have the dss reviever change resolution or should I let the tv change resolution.
Ex: dss on native led toggles from 480i,720p,1080i there is a signal loss for a few seconds before the display is visable on the tv.
If I remove native there is no signal loss and there is a visable resolution change displayed on the tv when viewing sd to hd and visaversa.
dss h10 ($200) tv JVC 56g886 ($2300)
Same results on HDMI and component.
Is the electronics on the dss for scalling = <>
the electronics on the tv.
Do you get what you for?
Any data would be greatly appreciated.
