Is this a good deal...
josef
Im new to all this i just bought a viewsat platinum 2000, now which dish do i buy?
is this a good ( http://cgi.ebay.com/SATELLITE-DISH-31-INCH-WINEGARD-STANDARD-KU-LNB-FTA_W0QQitem Z5823090128QQcategoryZ11726QQrdZ1QQcmdZViewItem )
or which dish do you guys recommend. Any advice or comments is greatly appreciated.
Username: Thill1951akalk
Post Number: 414
Wingard is OK..all depends what U plan on watching...which satellites?..The type and # of LNB's is MOST important!...
josef
i want to watch 110 and 119, since they seem to have more channels
josef
Username: H3lt3r_sk3lt3r
Post Number: 205
@josef
As stated in the auction the dish's primary use is FTA not DN, AND both 110 and 119 use a circular lnb not linear (like the one in that auction).
If you are only looking for DN, you'll be better off with dish500.
josef
ok, Is that all I need to receive channels on 110 and 119, a stock Dish 500.
Post Number: 211
@josef
Yes
josef
h3lt3r_sk3lt3r and thill1951 thanks for the help.
