Given that coaxial cable is a suitable medium for digital signals, why dont cable boxes with coax "tv outs" just output a digital signal and eliminate the need for DVI and HDMI??? Maybe for backwards compatibility with standard televisions? Would a coax tv out be considered a composite signal? Why not have 2 coax outs? One analog and one digital?
good question. over the air antenna sends coax digital or analog signal to tv w/o dvi or hdmi
fx
DVI and HDMI support copy protection schemes such as HDCP and 5C, an unencrypted digital signal fed via coax will not. Besides cable companies do send a digital signal over coax, it just requires the correct tuner to decode them, ie: a cable box, or a built in QAM tuner in your display will decode unencrypted High Definition programming.
