Silver Member Username: Iufan4lifeulPost Number: 645 Registered: May-05 | Easy enough... anyone know where I can get one? I have a 2 channel amp and therefore don't have one. (kicker kx450.2) |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1437 Registered: Mar-04 | you will have to get an FMOD to use as a SSF. http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3 the 20hz or 30hz highpass would what you want. |
Silver Member Username: Iufan4lifeulPost Number: 646 Registered: May-05 | http://cgi.ebay.com/Pioneer-CD-625-2Way-Crossover-NEW_W0QQitemZ5823996078QQcateg oryZ14931QQrdZ1QQcmdZViewItem Would something like that work alright? I heard that stuff like that could improve bass, is there any truth to that? |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1440 Registered: Mar-04 | most crossovers like that dont have a highpass filter that you can set to 20-30hz. |
Gold Member Username: InvainMichigan United States Post Number: 3983 Registered: Aug-04 | Harrison Labs - fmods. |
Silver Member Username: SixFlint, MI U.S.A. Post Number: 131 Registered: Oct-05 | pisses me off the jbl 1200.1's dont have a filter... |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1441 Registered: Mar-04 | FMODs work great...i use them on my jbl bp1200.1 |
Gold Member Username: InvainMichigan United States Post Number: 3984 Registered: Aug-04 | I have a set of 30 hz hp fmods sitting around somewhere. They work great if your amp doesn't have filters. |
