I recently purchased a JVC mini digital camcorder model GR-D72US. I'm able to transfer the videos to my PC and burn a video CD according to the instructions and the software provided via USB connection. The problem I have is when I try to view the video CD on my DVD/VCD player, I get an error message stating that the format is not recognizable. What am I doing wrong?
are you using mpeg2 compression? Check the format again when you burn to a vcd, you are probably using an SVCD format which is not always compatible with a regular DVD/VCD player. Also check if you are using NTSC or PAL, they should be compatible with your player.
