Username: Thejackal Kansas
Post Number: 8 Registered: Oct-05
Sunday, October 30, 2005 - 04:07 GMT 1 Type-S 12 1 Cerwin Vega V-Max 12 2 RE 12 2 Kicker Comp 12 1 Kicker Comp VR 12 Any other suggestions? I have around $400 to spend on the subs, amp, and box, so the sub has to be fairly cheap.
Username: Jakeyplaysbass Post Number: 126 Registered: Jul-05
Sunday, October 30, 2005 - 04:11 GMT 1 12" alpine type R dual 2ohm Hifonics BX605(very cheep and will get the job done) ported box should be 400 depending if u make the box or if you get it installed somewhere
Username: Poof Post Number: 76 Registered: Apr-05
Sunday, October 30, 2005 - 04:21 GMT im trying to bring hope back to those MTX haters so im gana tell you to go with a MTX 7512-04 or a 8512-04 and a hifonics BX605 or possible a bx1000-something like that....total its like 450 but worth it
Username: Iufan4lifeul Post Number: 630 Registered: May-05
Sunday, October 30, 2005 - 04:48 GMT 2 RE's. Best SQL combo there. Punchy, musical, accurate, loud, and deep. Can't beat 'em.
Username: Dustin3 Tigard,
Or
U.S.
Post Number: 61 Registered: Oct-05
Sunday, October 30, 2005 - 04:50 GMT the alphine type r's would sound good, you can get a kicker comp vr for 80$ on ebay. regularly 150$. good sub
Or
U.S.
Post Number: 63 Registered: Oct-05
Sunday, October 30, 2005 - 05:01 GMT the alphine type r's would sound good, you can get a kicker comp vr for 80$ on ebay. regularly 150$. good sub
