What do u guys think
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 221
here is my setup in a S10 Ext cab
Stock Alt and battery
2 12" Fusion PowerPlants in a Custom Built ported box ported to 38hz and 2.2cuft of air for each sub!
Audiobahn A8002T amplifier with SPL 4gauge amp kit.
Pioneer DEGP4700MP HU
Pioneer 6 1/2's TSG1640R in the doors
and Pioneer 4x6's TSG4640R in the Dash.
That is the setup! With that HU will I need an install kit?
What dB's can you guys gess i would hit! Iknow it is about impossible to tell with out hearing it but just take a gess! my subs are going to be facing upward! Will that sound good?
Username: Brady427
Post Number: 92
upward? im guessing your box is under your seat then?? Yes you will need an install kit for that HU...(wiring harness..dash kit..ect)
Paulding, Ohio USA
Post Number: 228
No my box is right in the back! where the jump seat is
Username: Cenus
Hicksville, Ohio Usa
Post Number: 559
not bad, the only thing i see that might cause a problem is your box is tuned kinda high, i would make it tuned lower to mabey 32-30hz, i would guess you will be hitting somwhere around 130-133db.
Username: Zacdavis
Beloit, Wi
Post Number: 307
it will be alot louder that :-)
Username: Cenus
Post Number: 560
well i just took a guess.
Paulding, Ohio USA
Post Number: 229
well dustin i cant tune my box anylower
Paulding, Ohio USA
Post Number: 230
it says a the port will not fit if i tune it any lower!
Username: Cenus
Post Number: 561
ohh well 38hz is ok, it will definitly make them sound louder.
Username: James1115
Wilton, Ct
Post Number: 4116
make sure you have your subsonic filter set no lower than 35 if you want them to last.
Paulding, Ohio USA
Post Number: 233
so 35 or higher on my amp and ill be ok?
Username: Zacdavis
Beloit, Wi
Post Number: 309
James Longo, I would've thought a gold member would give better advice than that.
Smitty, run your subsonic filter at the minimum level, that is where I run mine and most customers. (15-20hz)
As for your score, I wouldn't be surprised to see it doing 140's.
Username: Invain
Michigan United States
Post Number: 3951
Zac, he's gonna port his box at 38 hz. A high pass filter at 15 - 20 hz isn't gonna help him. Anything between 30 - 35 is what I'd use. 15 - 20 is just too low for my taste, I'd be a little leary.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1415
personnaly, i wouldnt set the SSF any higher than 25hz...
just my $.02
Username: Zacdavis
Beloit, Wi
Post Number: 310
Holy crap, another gold member (Joe) who doesnt understand what a subsonic filter is.
What a joke you guys, enlighten yourselves before you post.
Marshall, thank you. Finally, a post from a person who understands what a subsonic filter does.
Post Number: 1417
just think about it guys...
at the subs Fs, the amp will hit a "wall of impedance"...that sub's Fs is 28.5hz.
Username: Invain
Post Number: 3955
I know exactly what a subsonic filter does. Unfortunately, when I was younger I was running a ported box without filters, and had it unload on me. I learned a good lesson after that.
Filters are not like brick walls. Even with a 30 hz or so filter, which I would use, he won't even notice a huge difference from 30 - 25 hz compared to without a filter. The further you go, yes he's gonna be losing out on his low-end, but you have to make sacrifices somewhere.
He could be playing his sustem at pretty good steam, and hit a song that drops down to say 25 hz. He's now playing 13 hz below the port tune, that's a pretty big difference, and the box is not going to have very good control over the driver.
Post Number: 1418
one more thing, i looked on Fusion's site and they list the subs impedence at Fs...its 35ohms.
Username: Invain
Post Number: 3956
"at the subs Fs, the amp will hit a "wall of impedance"...that sub's Fs is 28.5hz."
You don't just hit a wall once you reach the driver's Fs, you hit a peak... If what you explain happened, there'd be a lot of people missing out of a large portion of the bass frequency spectrum.
that all depends on the slope of the filter as well.
5hz below tuning frequency is a good rule of thumb. for him 30hz would be fine. set it at 20hz and 21hz is not filtered, that's not good.
Username: Invain
Post Number: 3959
Subs are extremely hard to control below their tuned enclosure frequency, and they suck a tremendous amount of power in the attempt. 13 hz is a long ways down, and a sub unloading isn't pretty. It loses all damping, and they usually end up blowing the cone right off.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1180
What do I think? I think I need another beer!!!
And sounds like an alright system. And there's no knowing how loud it'll be...
Paulding, Ohio USA
Post Number: 234
Ok ill set the SSF to 20
and will that setup still sound good with the box tuned to 38hz?
Username: Invain
Post Number: 3967
I guess you didn't read anything I posted.... if you you want to be ignorant, go for it and set your filter to 20 hz. It's not my system, I could care less.
Paulding, Ohio USA
Post Number: 236
well man i dont mean to be deffinsive but i dunno who to believe here and more ppeps said 15-25
Username: Illuminator
Post Number: 2080
Joe knows what he's talking about. I'll vouch for him.
