New member Username: Aznvietboi87Post Number: 1 Registered: Oct-05 | i got two dual voice coil subs that are jl. its 6 ohm each and im going to run them in parallel but im not sure if the the amp i want will handle it. i want the hifonic 1600watt brutus ones, will it work with 1.5 ohms? am also open for other amp suggestions that i should buy. |
Gold Member Username: RovinTrinidad & T... Post Number: 1845 Registered: Jul-05 | u mean this ? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14887 Phoenix Gold Xenon amps also that funky 1-4ohms feature like JL amps & are way cheaper ,check out the 600.1 model ........ |
New member Username: Aznvietboi87Post Number: 2 Registered: Oct-05 | nope it's this one. http://mobile.jlaudio.com/products_subs.php?series_id=12 the D6 one. i have to of them and i need to know if this amp is stable with mine which is 1.5 ohm when it's wired in parallel. http://www.maxxsonics.com/hifonics/ampsnew_brutus.html# |
Gold Member Username: RovinTrinidad & T... Post Number: 1860 Registered: Jul-05 | (2) 6 ohms DVC subs can be wired into 1.5 or 6ohms since each of those subs are 300wrms that PG amp above can also work that Hif 1600Bx can also do the trick |
New member Username: Aznvietboi87Post Number: 3 Registered: Oct-05 | yeah i was just needed to be sure cause i heard amps turning off be cause of the ".5" ohm thingy now that i know for sure i can make my purchase thanx alot Rovin. |
Gold Member Username: RovinTrinidad & T... Post Number: 1861 Registered: Jul-05 | Well its pretty easy to check ohms fast when i have a site like this saved on my net bookmarks ..lol..![]() http://www.the12volt.com/caraudio/woofer_configurations.asp |
New member Username: Aznvietboi87Post Number: 4 Registered: Oct-05 | just one last quick question. most of the amps i checked out there only list 4 and 2 ohms wattage that the amp can handle or even 1 ohm but it also means it can handle the stuff in between also right? like mine 1.5 ohms |
Gold Member Username: RovinTrinidad & T... Post Number: 1863 Registered: Jul-05 | That JL site u posted showed that sub to 3ohms DVC HIF 1600BX specs RMS @ 4-Ohm: 1 x 550-Watts RMS @ 2-Ohm: 1 x 1100-Watts RMS @ 1-Ohm: 1 x 1600-Watts Hif amps are said to do about 70% of rated power @ 3ohms that would be 1/2 way between 1100 & 1600 = 1350wrms 70% of 1350 = 945 wrms ROUGHLY hmmm - might be a bit much check a lower model Hif amp maybe a 1500 or 1200 model the way i did here . If end result is a little above 600wrms thats ok ........i'm going to bed so u check it & i'll check u back in the morn . |
New member Username: Aznvietboi87Post Number: 5 Registered: Oct-05 | alright im planning to buy this amp http://cgi.ebay.com/HIFONICS-BX1205D-BRUTUS-CLASS-D-MONOBLOCK-AMP-BX-1205D_W0QQi temZ5822588802QQcategoryZ18797QQssPageNameZWD1VQQrdZ1QQcmdZViewItem should this work with my subs? |
Gold Member Username: RovinTrinidad & T... Post Number: 1866 Registered: Jul-05 | that'll work out to 735 wrms - yea that could work note that its $31 s/h from eabay this is cheaper cause s/h is free http://www.carstereoland.com/shop/shop_goodsview.asp?Top=1&g_code=20057251822347 055475 |
