John Bk Unregistered guest |
Posted on Hi I have a Multistar Pantec.My EPG is very fast(mostly it takes less than 5 seconds to bring the info)but the time and date are not accurate. It shows next day's date (for example if now is Nov 3Th the date shown in EPG is some diferent time in Nov 4Th) Do you have the same problem?Is there anyway to fix it? Thanks |
Silver Member Username: H3lt3r_sk3lt3r
Post Number: 280 Registered: Oct-05
Posted on @John Bk In your receiver's time setting change the Time Zone . |
Posted on That was great. Thanks |
