Problem With Fortec Star Life Time!
TIEK
Guyz, I downloaded the fix to my reciever using the blacklist uploader and after that i hooked it up to my dish but it did not work i got 99%level and quality even if i didn't hook it up. When I search for channels it does not find a thing! I know for sure that my dish workz because i subscriped for 15 channels from DN and they'r workin n' um tryin to do this so i can get the extra channels considerin that I have the Fortecstar Life time from before!
Thankz
Username: Thill1951akalk
Post Number: 374
U double posted,which is a NO NO...close this thread...U've been answered in another !
TEIk
Itz just that the other thread iz too long n' takez long to load, So i started a fresh one! I guess wat i wz tryin to say iz dat I hav 2 recievers, n' i uploaded da new bin on the Fortectstar Lifetime n' then I couldn't upload anything anymore!
Srry for da double post!
TEIk
To thill1951:
I did not say that, I said that before Nagra2 came up I used to have a fortecstar Lifetime reciever and it worked fine. after what happened with N2 i subscribed for 15 international channels, n' i didn't have to do anything but replace the reciever, now that N2 fix is out i am trying to get the 150 channelz in the international package back. When i downloaded the fix to the FOrtec reciever, using a blacklist uploader, n' did a channel serach, i could n't get any channelz, the only thing i got waz a level and quality of 99% n' it wz the same even if i dont have the dish connected to the reciever, Even though i have it pointed in the right direction!
Thankz
TIEK
I really don't hav a clue bout wat i can do because when i try to flash the receiver again it does not work
