New member Username: Aznvietboi87Post Number: 8 Registered: Oct-05 | i have a 98 integra and i just got to jl subs for it but i dont really want to spend any money on a new head unit and the oem head unit doesnt have any rca jacks behind it. i already laid out the rca wiring and didnt put any speaker wiring along with it. is there a simple solution to using my amp without getting a new headunit and putting speaker wiring? |
James Palanza Unregistered guest | You could get really creative and do some wire splicing, or you could buy a converter that takes ur regular wires and turns them into rca. I forget what they are called but they exsist. |
New member Username: Aznvietboi87Post Number: 9 Registered: Oct-05 | i like your converter idea, do you know where i can get one for cheap? and also how well do they work? |
New member Username: Aznvietboi87Post Number: 10 Registered: Oct-05 | would this work? http://www.pac-audio.com/products/loc.htm -Trunk-LOC |
Bronze Member Username: TjmutlowPost Number: 74 Registered: Sep-05 | No. it will not work, You need a Line out converter, preferably a good one. if You do not care, walmart sells them. |
Bronze Member Username: CrashfactoryxPost Number: 18 Registered: Oct-05 | using one now, not bad...gotta mess with them a bit to get a good sound, but it's cheaper (20$) than buying a new head unit.... |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 557 Registered: Oct-04 | If you spent all that money on JL setup, I'd go buy an HU and make them sound good. |
Bronze Member Username: Aznvietboi87Post Number: 11 Registered: Oct-05 | http://www.pac-audio.com/products/loc.htm isnt this a out line converter? i got my jl subs cost be 300 plus i have to get a amp (another 200) so i dont really have the cash to get a head unit just yet. |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 1442 Registered: Mar-04 | that Pac-audio LOC will get the job done. |
