PLEASE HELP-2 10' audiobahns and can't decide on amp.
Username: Subthump13
Norfolk, Virginia United States
I really need some help picking out an amp for a boxed set of 2 10' audiobahn subs. The given wattage is 600W, but i dunno how many watts I should juice up my subs with. I heard that some amps. put out more watts than what they say. I have a couple amps. picked out that I can get a great deal on:{{Pyle "Red Elite" 2-Channel 600 Watts Max Amplifier}}--{{Pyramid "CRYSTAL" 2 Channel 600 Watt Amplifier}}--{{SPL "SERIES V" 2-Channel Amplifier 620 Watts Max}}
Could someone plaese tell me which one would go great with my sub set. You can E-mail me at hatteras@cox.net
i would stick with a kicker, audiobahn or mtx amp...
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 346
noooooo all 3 of those amps are complete trash...look at Kicker KX600.1, MTX 801D and JBL GTO 600.1 for some cheap and good quality amps.....off ebay of course
Username: Carolinablue637
Lincoln, NE USA
Post Number: 23
i would agree with quickshot. dont go cheap on your amp. i made that mistake when i was first getting my subs and then i saved up and bought a kicker 1200.1 amp and am wayy happier with it
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 727
Also Morgen, u should really try and get a mono amp
Username: Rovin
Trinidad & T...
Post Number: 1760
Most importantly Morgen should post the model no of those subs in case its max wrms he's talking about so we can all be sure .......
why wood i need a mono amp? also, wut channel amp should i get (2,4,multiple)---I saw a Lanzar "Heritage Series" 2-Channel 600 Watts Max Amplifier that I thought was great--is it good or not? Wut is this whole thing about RMS--wut is it and how does it effect on wut watt amp. i should get for AudioBahn Dual ABP10T 10" Tuned Bandpass System 600 Watts RMS.
Username: Rovin
Trinidad & T...
Post Number: 1792
Mono amps are especially built to power subs .
u mean this ?
http://www.sonicelectronix.com/item_85.html
# Power Handeling: 400 Watts RMS
# Impedance: 4 Ohm
look like it needs 400wrms @ 4ohms if i'm not mistaken
then get the Hifonics BX1605D
