New member Username: ThejackalKansas Post Number: 1 Registered: Oct-05 | I'm looking to get a sub for my first system, and while I've looked around some, I'm wondering what people would recommend for me. I have a very limited budget which is around $400 for everything. A few subs which I'm looking at are Alpine Type-Rs, Cerwin-Vega V-MAX, And Kicker Comp VRs. Hopefully, I can find somthing that gets loud but doesn't sound like garbage, and maybe some suggestions on amps. Since I listen to lots of rap and rock, It looks like a ported box is the way to go. |
Gold Member Username: RovinTrinidad & T... Post Number: 1732 Registered: Jul-05 | "around $400 for everything" - u mean 2 12s & an amp for it ??? |
New member Username: ThejackalKansas Post Number: 2 Registered: Oct-05 | That would be nice, but I can settle for one 12" at that price. |
Gold Member Username: RovinTrinidad & T... Post Number: 1734 Registered: Jul-05 | ok ,if its $400 for 1 12 & an amp then 1 12' type R 4ohms DVC = $136 online shipped http://www.carstereoland.com/shop/shop_goodsview.asp?Top=1&g_code=20057117255390 57298 & http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14927 = $258 shipped .......$6 change to buy drinks. |
New member Username: ThejackalKansas Post Number: 3 Registered: Oct-05 | Thanks, and this wont kill my stock alternator will it? |
Gold Member Username: RovinTrinidad & T... Post Number: 1735 Registered: Jul-05 | Not really - anything over 1000wrms might call for a upgraded alt . what else is going with this set-up ????? |
New member Username: ThejackalKansas Post Number: 4 Registered: Oct-05 | I already have an alpine deck and some kenwood speakers. If I'm going with a ported box, are there any decent premade ones that will go nicely with the Type-R, or will I have to build one? |
Gold Member Username: RovinTrinidad & T... Post Number: 1736 Registered: Jul-05 | Easiest way to tell if your system needs more juice is if headlights start blinking .... Go slot ported - U will have to go on Alpine's website tech pages & check the rec box volume & tuning freq . A box for it online is about $50 so look for 1 made of 3/4 mdf ,with the rec vol & tuning freq ..... |
New member Username: ThejackalKansas Post Number: 5 Registered: Oct-05 | Alright, thanks again. |
New member Username: ThejackalKansas Post Number: 6 Registered: Oct-05 | http://www.circuitcity.com/ssm/Bass-Slammer-Single-Vented-Subwoofer-Enclosure-BS 112V-/sem/rpsm/oid/119723/catOid/-13094/rpem/ccd/productDetail.do This looks like it will work, but I can't seem to find anything that is under the $100 range for boxes. Does anyone know where I might be able to get one for cheaper? |
Gold Member Username: RovinTrinidad & T... Post Number: 1744 Registered: Jul-05 | http://sonicelectronix.com/cat_215.html sub/box combos http://www.woofersetc.com/index.cfm?fuseaction=category.display&category_ID=14&m fg_account_ID=48&sort=account_name&=Update+Selection u need to google & not look @ those big name stores |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 550 Registered: Oct-04 | It might benefit you to learn how to build a box yourself because of how much it costs to buy and ship a box. Just a thought on my part. |
New member Username: ThejackalKansas Post Number: 7 Registered: Oct-05 | The problem with the ones at sonicelectronix is that they don't say what the volume is them. |
Silver Member Username: Rob_pregRoyal oak, Michigan United states Post Number: 103 Registered: Sep-05 | try klausaudio.com they'll build you a custom box for a pretty good price |
