Where can I get a 13 inch enclosure? Sealed or Ported for W6V2?
James Palanza
Right now, I need to find an enclosure for a 13 inch w6v2, and thats turning out to be difficult. Am I just going to have to build one? I have the spec's from JL's website.
Also, which would be better for hitting low and hard, sealed or ported for a 13w6v2? I listen mostly to alternative rock, but I want to be able to play rap and get some serious bumps.
Get the 13W6 Prowedge Jl box. They dont make a 13" HO if you wanted ported & very large box.
Friend got one loaded with the sub a month ago for $640. Was cheaper as a system then buying separate but I dont think the box is more than like $100 single. He paid like $80 with the sub loaded !! Saw a guy on E-bay that builds them for that sub, but I'd get the JL.
