Old Kenwood without SPDIF - How do I get true 5:1??
Username: Vengeanze
Hi
My first post. :-D
I recently was given an old Kenwood reciever KR V990D with Wharfedale 7 2 speakers.
I got all 5 speakers up n running. White noise test all ok.
Got the reciever hooked up with my United DVD3151 (lousy I know).
When I connect sound through RCA everything works ok but I suspect that RCA won't give me 5:1 sound.
So I saw this review:
"Firstly, this unit was produced BEFORE the era of DVDs so there's no digital audio interface (SPDIF) for DVDs, but if you still have a relatively new LaserDisc player, this might be the perfect unit for you because there's actually a coaxial digital interface for LD players."
So I ran to the shop and bought me a coaxial cable that looks like a RCA-cable but says "3C-2C 75 U Coaxial Cable" on it.
Connected my DVD to the LD Digital In port on the reciever but...nothing.
No sound whatsoever.
There's a little diod that is supposed to lit when the reciever sense a AC-3 signal (same as Dolby Digital 5:1 if I'm informed correctly) but it never lites.
I tried changing output type on the DVD from Analog to some kinda PCM.
Actually tried a zillion different settings and cables but no joy.
So anyone out there who's got experience of old pre-DVD recievers and coaxial cables??
Here's an URL to the PDF-manual for the reciever.
http://www.la-famiglia.se/OM-KR-V990D-1996-KUSA.pdf
Username: Vengeanze
*ahem* Just checked the specs for my DVD.
It says:
"Features of audio specifications
- DTS (Digital Theater System) digital audio output
- Dolby Digital 2ch output
Main Features
- DTS-compatible digital audio output.
- Audio output: Dolby Digital 2ch mixed stereo output, MPEG-II Audio output, Coaxial and Optical digital output, Linear PCM decoding output."
Guess my old reciever doesn't support DTS and my DVD doesn't have Dolby Digital 5.1 (just 2-ch stereo).
Any way around this or do I need a new DVD that supports Dolby Digital 5.1?
Username: Jan_b_vigne
Dallas, TX
Post Number: 6330
From what you've posted here, you would do best to buy a DVD that has DD included and then get a receiver which will update all of your connections.
