Sub distortion
Username: Turok6_007
Post Number: 26
i have an old galaxy woofer in a small ported box but when i put it kind of high on my home theater amp which is only 50 max for the sub it sounds realy crappy.i think it might be blown out but it still makes a lot of bass.what could be the problem?
Username: Rideredder
Cornell, IL USA
Post Number: 71
How many watts is the sub? You might be underpowering it.
Post Number: 28
its 150 peak
Post Number: 30
its also a 4ohm svc
Username: Young_james
Post Number: 62
that could be part of it, and besides, you shouldn't hook up a 4 ohm sub to a 8 ohm amp.
