Ps2 wont work on new television
Username: Grudge
i just bought a sharp 32c540 and i cant get any of my systems to work especially the ps2. i have tried with a rf switch but not the actual av cables. i also tried a nes and snes, with the appropriate inputs, and none of them worked either.
has anyone ever heard of a problem like this before. i called sharp and they wanted a tech to come look at it.
any help on this is appreciated
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2532
bump
Username: D_singh
Post Number: 56
what is meant by this term "bump"?
Post Number: 2853
2 push a thread back to the top of the board so people will see it
Username: Reinhart
Post Number: 264
Check the settings and connections on your television.
For instance, if you have the AUDIO OUT hooked up on your TV to your receiver, this might cause the TV to cut off its own speakers as you would be listening to the audio from the receiver.
Another possibility could be your TV's sound settings, like if the speakers were set OFF in the menu. - Reinhart
