Whats so bad about factory renewed?
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 136
Whats so bad about this amp i would save $200.
http://www.cardomain.com/item/KIC04KX60012
Username: Yada
Post Number: 37
it has a 90 days back waranty. If you like the amp and will save a bundle why not. Test it out, if ya don't like it, send it back. Check ebay also, you might be able to get it brand new cheaper than the online stores most of the time.
Username: Jake110011
Jackson, Michigan
Post Number: 42
Its a amp somebody sent in because it quit working. Kicker will fixthe amp,then sell it again. Its as good as new. They test the shiit out after they fix it. Sounds like a deal to me.
And with a warranty, what can you lose?
Username: Edster922
Post Number: 2657
honda,
check out ubid.com they have lots of kicker amps right now.
Glidden, Iowa U.S.
Post Number: 137
whats better the first amp or this one
http://www.cardomain.com/item/MTXTA4501
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1365
the kicker kx600.1 is better (IMO)
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1312
furbies are hit or miss. in my experience, it's more hits than misses though.
Username: Tjmutlow
Post Number: 63
not if refurbed by manufacture and not third person. i sell quite a bit and only have had a few go bad, mainly TVs and radios though
Username: Mikechec9
Post Number: 1325
that's what i said. i agree. more hits than misses.
