Power Acoustic or Pioneer Amp
Username: Dubz_on_my_jeep
I have been looking at amps and the power acoustic 980 watt amp looked decent. I didn't know if i should go with that or a Pioneer 760 watt.
I didn't know if any body has had any experience with the power accoustic. The amp will be hooked up to either 2 kicker comp vr's or 1 or 2 JL w1 13
Also which setup is better the comp vr's or the Jl's
Username: Basshead86
Ocala, FL USA
Post Number: 2505
i would choose the JL's personally.
i would also look into maybe getting a kicker amp. i'm not too fond of Pioneer or PA amps.
kickers are excellent amps for the money.
To push the 1 or 2 JL W1's what kind of kicker amp would i need...and how much would it cost. Because i dont want to spend over 700 bucks (give or take a little bit)??
To push the 1 or 2 JL W1's what kind of kicker amp would i need. And how much will it cost? I am only looking at spending around 700 bucks total on everything (Give or take a Little)
Username: Wolf_hound
Post Number: 67
whats the rms on the w1 yeah stay away from power craptastic, pioneer i dont know havent had experience with them.
Username: Rovin
Trinidad & T...
Post Number: 1560
Lucas - Are u sure u know prices ? a single 13w7 = $700 !
Also do not put cheaper amps of good subs , u can do vice versa though....
for $700 u can get 2 12" comp vrs or Alpine 12" type R & a good Orion 1200 amp & a prefab box if u can't build 1 yourself .....
Username: Fandim
Reno, Nevada United State...
Post Number: 349
He said a W1 13. :-) Not a 13W7. :-P
Username: Rovin
Trinidad & T...
Post Number: 1573
oh crap - when i saw "JL w1 13" , my mind was thinking 13w7 ...lol
so its this then - http://mobile.jlaudio.com/products_subs.php?series_id=17
then that would be 1/2 the power of a current model compvr .
